wiring need help
hey guys i got a 89 crx its not a hf or si just a crx im putting my JDM B16A in it. all obd0 i need to no how to wire the mpfi and all that i got the vtec and that wired in i just need the mpfi. its alll on the motor i just dont no what to do with the car side it has that big plug
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Check the FAQ's this has been covered thousands of times.
Since the car is a DX no other engine harness will plug into the plugs by the passenger side firewall except for the DX and MAYBE the STD harness (I am not 100% sure on the STD harness connecting). The HF engine harness will not work unless you replaced the entire underdash harness with an HF one because the round plug is different.
The HF engine harness doesn't even directly plug into the SI harness either without swapping a few pins around on the plug you are having troubles with.
awdlaser1
10
May 10, 2009 01:29 PM
Turbo EH2
Sep 28, 2006 09:21 PM
Acuraman918
Jun 19, 2004 01:26 AM
