Help Please...Need info...First swap into Crx???
Old Jun 24, 2009 | 08:05 AM
dc2itr617's Avatar
Default Help Please...Need info...First swap into Crx???
I have a 91 Honda Crx. Im getting ready to order a first gen b16 swap. Now i know i have to get the shift linkage from hasport but my question is can i use the stock mounts that are coming with jdm swap or do i have to use an aftermarket mount kit?
Old Jun 24, 2009 | 08:15 AM
jo7man4's Avatar
Default Re: Help Please...Need info...First swap into Crx???
You need to order the hasport ones or any aftermarket mounts for that matter as long as they are for D to B swap, no you cant use the ones that come with the jdm motor why you ask, I honestly don't know some one that does know will answer this for you. Also is your CRX a Si or Hf? If not your gonna need to do the dpfi to mpfi swap and wire for VTEC and oil pressure sensor but I'm sure you knew this already or hope you do just making sure.
kevin_
Oct 14, 2005 09:46 AM
4thgenlude
Aug 28, 2005 03:29 PM
sabertooth
Feb 4, 2004 02:40 PM
stickolas
Jan 16, 2003 09:19 AM
91ReXSI
Nov 12, 2001 11:43 AM
