Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2001 MDX Brake Question
Old Jun 24, 2009 | 07:38 AM
7mile's Avatar
Default 2001 MDX Brake Question
hi,
i'm going to do a rotor replacement. do i need to press out the rotors? or is it just a simple replacement.
i remember doing my old accord, took a while.. thanks just prepping for the heat..
Old Jun 24, 2009 | 08:54 AM
Splaturn's Avatar
Default Re: 2001 MDX Brake Question
Remove the brake caliper anchor plate and the caliper, make sure you hang it with something (metal hanger) rather than letting it dangle and stretch the hose or cause breakage.
Remove the screws that retain the disc.
Take two 8x1.25mm bolts and screw it into the disc brake and let it push itself away from the hub, make sure you only do a few revolutions per screw at a time to make it easily removable/not stuck or cocked.
Pull the disc from the hub.
Pretty easy to do, if it's your first time, take it easy and don't expect a 30 minute job.
honvic
Suspension & Brakes
14
Mar 12, 2012 01:46 PM
RX3
Acura TL, RL & ZDX
Oct 18, 2005 07:16 AM
Sportsguy
Feb 10, 2005 02:01 PM
fiebru1119
Nov 9, 2002 12:06 PM
leechungsr
Aug 25, 2001 03:39 PM
