4 ABS codes after messing with under-dash fuse box.
99 Integra LS coupe 5-speed.
The under-dash fuse box was loose. I went down there moved it around a bit and put on the 2 nuts that were missing. Now right after that, I start the car and the ABS light is on. I pull the codes and get:
18- Wheel sensor RL
32-FR out solenoid
54-Fail Safe relay
81- ABS CPU
I am really having a hard time believing that all these went bad at the same time. My assumption is that there is a plug or group of wires somewhere that I damaged/unplugged.
Any insight or suggesting would be appreciated.
thanks.
18- Wheel sensor RL
32-FR out solenoid
54-Fail Safe relay
81- ABS CPU
thanks.
I also have 99 integra LS, Did you fix the problem yet?
I park my car for 2 day then ABS light is on and these are the code I pulled.
18- Wheel sensor RL
54-Fail Safe relay
81- ABS CPU
(From reading couple different sites, when wheel sensor fail the ABS CPU also show up for what ever reason that is.)
So i reset the code and finally only one show up "18- Wheel sensor RL". Then is go way for couple day then come back agin, "18". Again i reset it but after driven 2-3 miles some 20-30 miles it came back, "18". I then to reset again but after it flash twice the ABS light stay on even how many time i reset it.
So, it look like a time to drop it off at the garage. After $300 ($160 part, $130 labor and tax) it fix. They replace the rear right wheel sensor. I will keep my finger cross hope that ABS light not going to come back again.
18- Wheel sensor RL
54-Fail Safe relay
81- ABS CPU
something similar happened to my 94 teg, replaced a fan and the abs light came on- pulled a 12- abs pump motor, i really doubt replacing a fan could cause an issue with that but the light remains on. who knows.
hope someone chimes in that could help out- things like that are annoying.
