Partial Throttle Issues . Dohc ZC
Old Jun 23, 2009 | 08:20 PM
es.roadster's Avatar
Icon6 Partial Throttle Issues . Dohc ZC
h-t
so yesterday i had my p06 ecu chipped with obd1 dohc zc maps;p29.
the car isn't running really great @ partial throttle. it has this laggy
feeling only under 5,000 rpms. @ WOT, there are no problems, revs freely
and the power is just, wow. so yeah, i've been searching around honda-tech
and all i got as a possible answer was change out the o2 sensor and fuel filter.
more about the partial throttle issue.
let's say this happens 97% of the time i'm driving. meaning like sometimes
my car would drive normally with no lag/loss of power/LIGHT jerk feeling.
background;
90 civic dx obd1 converted
92 jdm dohc zc with 60xxx miles mated to 91 civic ex tranny.
ebay 4-2-1 header, no cat/resonator, stock crx si muffler(dual tip)
cheap short ram intake
92 civic dx distributor, drilled in order to set ignition timing to perfection and to fit lol.
ecu chipped by Redzone.
o2 sensor disabled
"custom" integra LS maps;; copy and pastedededed the dohc zc maps
help me out h-t!
my car will deathed
*forgot to add*
my car backfires also at 4k shifts..
Old Jun 23, 2009 | 08:26 PM
alx_90ef's Avatar
Default Re: Partial Throttle Issues . Dohc ZC
try getting the dohc zc dizzy
Old Jun 23, 2009 | 08:30 PM
i have one but it's obd0.
the dizzy works fine. what i'm saying is that, this happened
after i got ecu chipped. and from that this probably caused
this problem i'm having with my car.
thanks
Old Jun 23, 2009 | 08:32 PM
alx_90ef's Avatar
maybe they didnt chipp the ecu correctly
Old Jun 23, 2009 | 08:49 PM
you spelled "dohc" wrong in your sig
Old Jun 26, 2009 | 12:21 PM
RedZone's Avatar
The ECU works fine, but what you must understand that its not ZC maps just coppied and pasted. I made that map from scratch using an LS map as a base and then started to make changes as I see fit. its a base map and just that. the car should be tuned on a dyno to make sure everything is in order and that the car runs correctly. I know you came by yesterday and I made some changes and made sure you knew that you should really tune the car for safe measure.
Old Jun 26, 2009 | 02:06 PM
i appreciate your work jeremy. you helped me out alot even though i've been there for two days. you do good work and trust me. i was just wondering if it was something else that might have caused this problem, not your work. well hopefully, i'll swing by sometime next week for the dyno tune. i'm excited lol. heard i could probably make somewhere close to 110whp to 120whp
looking forward to it though man. see you guys soon!
-Evan
tyler100
Jan 15, 2009 07:02 AM
remoer
Oct 29, 2008 10:01 AM
jtmoney2002
Jul 11, 2008 01:54 AM
Jmorin
Feb 10, 2004 09:38 AM
