Acura Integra 1994-2001 DC2 Wheel Bearings
Old Jun 23, 2009 | 06:09 PM
Master23's Avatar
Default Acura Integra 1994-2001 DC2 Wheel Bearings
To see the original article with images check it out here: Integra DC2 Wheel Bearings. Garage411.com
Removal
1. Remove steering knuckle. Using Front Hub Remover/Installer (07GAF-SE00100), Hub Remover/Installer Base (07GAF-SD40700) and hydraulic press, remove hub from steering knuckle. Remove splash guard screws and splash guard. Remove bearing retaining snap ring and knuckle ring from knuckle.
2. Using bearing driver and Attachment (07746-0010500), base and hydraulic press, remove bearing from knuckle. Using commercially available bearing separator, remove inner bearing race from hub. Clean knuckle and hub thoroughly before reassembly.
Installation
Using press and old bearing, install NEW bearing into knuckle. Install snap ring into knuckle groove. Install bearing retaining snap ring splash guard. Invert knuckle. Press new bearing into hub. Press hub into knuckle. To complete installation, reverse removal procedure. Check alignment.
roterx7
30
Mar 13, 2015 05:40 AM
kornerk12
May 21, 2007 01:41 PM
Bnjmn
Sep 20, 2005 03:43 PM
low430
Aug 29, 2005 08:32 AM
Civmochris
Nov 16, 2003 06:13 PM
