Help....dizzy problem?
Old Jun 23, 2009 | 05:16 PM
johnny_bighood's Avatar
Default Help....dizzy problem?
I have a 4 door 92 JDM Civic SiR with b16a. The car seemed to be bogging and losing power so I was testing the plugs by taking out the wires while the car was idling. I started with number 1 and the tone of the car didnt change when i took of the wire. When I put ack the wire on the plug. the car shut off. I tried to start it back and it didnt start. I removed the number 1 plug and saw that it was burnt. I changed the plug anyway. The car hasnt started since it shut of while i was testing the plug the first time. I checked for spark comming from each of the wires and there is none. I chaged the coil in the distributor and that changed nothing. Is there a fuse for the current goin to the distributor? If so where is it and what else could be the problem?
Old Jun 23, 2009 | 09:25 PM
b20c's Avatar
Default Re: Help....dizzy problem?
get a good dizzy check the main relay
Old Jun 24, 2009 | 03:28 PM
wishihadboost's Avatar
New User
I had this same problem, except replacing the coil fixed my problem. Ignitor? Try a friends dizzy or something and see if that helps.
SVOHK
Jun 18, 2015 08:46 PM
FTNW
Dec 7, 2010 01:10 PM
johnny_bighood
Jun 23, 2009 06:44 PM
andrew714
Dec 13, 2007 09:35 PM
StreetRiot_DRE
25
Dec 10, 2007 07:19 PM
