Honda S2000 Honda S2000
Honda S2000 2000-2004 AP1 Dashboard Removal and Installation
Old Jun 23, 2009 | 05:06 PM
Master23's Avatar
Default Honda S2000 2000-2004 AP1 Dashboard Removal and Installation
To see the original article with images check it out here: Honda S2000 Dashboard Removal and Installation. Garage411.com
Tool needed
* KTC trim tool set SOJATP2014
NOTE: Use the appropriate tool from the KTC trim tool set to avoid damage when prying components. Have an assistant help you when you remove and install the dashboard. Take care not to scratch the dashboard, body and other related parts. Put on gloves to protect your hands.
CAUTION: SRS components are located in this area.
1. Make sure you have the anti-theft code for the radio, then write down the frequencies for the radio's preset buttons.
2. Disconnect the negative cable from the battery, and wait at least 3 minutes before beginning work.
3. Remove these items:
  • Gauge Cluster
  • Radio panel
  • Audio unit
  • Steering column
  • Passenger's dashboard lower cover
  • Front console cover, both sides
  • Passenger's airbag assembly
  • Kick panel, both sides
  • Front pillar trim, both sides
4. Disconnect the engine wire harness connector, engine compartment wire harness connectors, door wire harness connectors, rear wire harness connector, steering hanger beam wire harness connectors, SRS main harness connector, radio antenna harness connector, ECM connector, keyless entry control unit connector, and convertible top control unit connector.
5. Remove the ground bolts.
6. Detach all of the harness and connector clips.
7. Open the doors, remove the caps, then remove the bolts and screws, and lift up on the dashboard to release it from the guide pins. Take care not to scratch the center console and shift ****.
8. Carefully remove the dashboard through the front door opening.
9. Install the dashboard in the reverse order of removal, and note these items:
  • Make sure the dashboard fits onto the guide pins correctly.
  • Before tightening the bolts, make sure the dashboard wire harness and steering
    hanger beam wire harness are not pinched.
  • Make sure the connectors are plugged in properly.
  • Reconnect the negative cable to the battery.
  • Enter the anti-theft code for the radio, then enter the customer's radio station presets.
  • Reset the clock
  • Do the PCM idle learn procedure
ambitiousone
Audio / Security / Video
Aug 1, 2007 11:44 AM
jjluna2
Honda S2000
Jan 3, 2007 02:02 PM
tizero1
Honda Civic (2001 - 2005)
May 5, 2006 06:56 AM
CHiNkStEr
Honda S2000
21
Oct 25, 2005 10:07 PM
icmikehunt
Acura TL, RL & ZDX
Jul 23, 2004 09:19 AM
