About to clean EGR ports, but they are welded.
If the ports are welded, you can just drill out a hole and then weld it back up. If that's not an option, perhaps epoxy the holes or drill the holes so that replacement plugs from Honda fit right in. Or you can just try pouring some seafoam into your egr port and hope that cleans things up.
yeah do what the guy with 3 posts says.
Teglessb18
Jan 3, 2008 08:26 AM
