H22 CRX build.
Old Jun 23, 2009 | 11:36 AM
Benjurman's Avatar
Default H22 CRX build.
Im new to the boards....not to the honda scene
I am in the process of building a boosted H22 crx.
I plan on getting the explicit speed mount kit with t-bars.
how did your crx h22 turn out?
does the skunk2 IM work with the swap without mods? (firewall, and hood clearance)
how did you do your turbo manifold on the H powered rex?
anything would be helpful..... thank you
Old Jun 23, 2009 | 11:45 AM
Smokinsax's Avatar
The Boot
Default Re: H22 CRX build.
check this thread out; its a good start for you:
https://honda-tech.com/forums/showth...ficial+boosted
member 2point2 comes to mind when I think of boosted H22's in a CRX...there are a few others that are floating around on this site.
Old Jun 23, 2009 | 01:35 PM
Benjurman's Avatar
thank you... found some good threads from that....
I still cant find anything about the skunk2 manifold and fitment
Old Jun 23, 2009 | 10:42 PM
crx22's Avatar
I did the skunk2 manifold with mine just look for posts by me and you will see the thread.
I would _NOT_ recommend putting it on.
It is way to big to fit in there...I already broke one booster and had to put another one in because the pedal went down too far (bad master cylinder) and it hit the area I had beat it in.
I used the hasport mounts and had to raise the rear mount to get it to clear, but on a side note the axles are much straighter now.
Old Jun 24, 2009 | 07:52 AM
Benjurman's Avatar
Yeah, I just talked to John at explicitspeedperformance and he was telling me that the skunk 2 is 1 1/2" longer than stock, and with the mounts they sell you have about 1/2" clearance with the stock manifold.
He recommends the rosko racing euro-r manifold
www.roskoracing.com
it seems that this is what I will be doing
because the euro-r manifold is shorter than stock... you gain an additional
1/2" of clearance on the firewall
any other information on the EF/H22 swap would be helpfull...would like to get all my ducks in a row
what tranny do you use? what would be the best ratio h/F series tranny?
djnikko
Jan 6, 2015 01:36 PM
djnikko
Jan 2, 2015 06:36 AM
Fly1865
Mar 17, 2005 03:35 AM
accord2nv
Nov 29, 2004 07:07 PM
