butterfly for gsr
Sounds like you are running a chipped ECU that doesn't support the IAB (controls the secondary butterflies).
You can get IAB to work by -obviously- getting the right ECU. You can also modify some ECU's to add IAB control - requires new chip to be burned with GSR mapping.
you could get an aftermarket intake manifold, it's a single stage IM so you wouldn't have to worry about no butterflies. Also you already have the ecu to go with it.
