My exhaust theory on overheating
Old Jun 22, 2009 | 09:35 PM
jonesdesign's Avatar
Default My exhaust theory on overheating
ok, exhaust is broken just as it get to the begining of the pipe, which essentially is just past the motor, could an engine overheat if in idles for a bit of time in 100 degree weather, since i think exhaust is rising back up into the engine compartment?.?...
Old Jun 23, 2009 | 05:53 AM
19Accord97's Avatar
Default Re: My exhaust theory on overheating
It could, especially since one of you fans are not working which you need to get fixed asap.
Why not just go to Autozone and buy an exhaust patch repair kit? They are like $5
Old Jun 23, 2009 | 06:06 AM
well i did get the other fan working now, and it takes a long time in heavy stop and go traffic with the a/c on to get it to start to overheat, I have a many holes in my exhaust, im taking it to a muffler shop to get it patched
Old Jun 23, 2009 | 05:31 PM
anyone else have thoughts on this?
Old Jun 23, 2009 | 05:51 PM
TheMuffinMan's Avatar
He knows where you live!
Most likely you need to change the coolant, verify you have no leaks, and make sure the fans both come on when the AC is turned on.
I do not think a minor exhaust leak will cause you to over heat. I have run with just the top portion of a header and not overheated.
Old Jun 23, 2009 | 08:49 PM
new coolant
new hoses
new radiator
old rad cap
old OEM Thermo (worked just fine)
Old Jun 23, 2009 | 08:53 PM
EF8IGHT's Avatar
Originally Posted by jonesdesign
old rad cap
Im thinking that is your problem.
CRX Si69
Welding / Fabrication
Apr 17, 2012 03:08 AM
Acidcrakker
Sep 18, 2007 08:15 PM
hundo
Honda Civic (2001 - 2005)
Jul 22, 2007 10:51 AM
1989CivicSi
Oct 2, 2006 01:00 PM
Pythagoras
Mar 14, 2005 05:18 PM
