2001 Integra GSR front brake pads interchangeable with 95 Civic EX (w/rear drums)?
Old Jun 22, 2009 | 06:05 PM
variable's Avatar
Icon2 2001 Integra GSR front brake pads interchangeable with 95 Civic EX (w/rear drums)?
My daily 95 Civic EX Coupe (with rear drums) is in dire need of front rotor and pad replacement. I have a set of front rotors and pads off my 01 Integra GSR that are still in good shape as I replaced them with upgraded aftermarket items. I cross referenced the part #'s for the Brembo OE replacement rotors and they are the same for both cars, but the Hawk HP+ pad have different #s for the two cars. Based on this, I am fairly sure the OEM GSR front rotors are interchanble with the 95 EX rotors, but I am unsure about the pads, (maybe the GSR has bigger calipers?) Does anyone know for sure if the OEM GSR front rotors/pads will swap right in to a 95 EX? This would save me a lot of $$$..
Old Jun 22, 2009 | 06:07 PM
dE.fUsEd's Avatar
Default Re: 2001 Integra GSR front brake pads interchangeable with 95 Civic EX (w/rear drums)
pretty sure they are the same. best way to figure it out is to pull the pads, and place them on top of the other ones. if everything matches up, you should be fine.
jksmith
Mar 10, 2010 09:52 AM
b16racereg6
Sep 30, 2009 08:40 AM
JDMTEG98
Honda Civic (2001 - 2005)
Jul 10, 2009 12:38 PM
blackhecilopters
13
Jan 22, 2006 09:17 PM
tkycgo
Nov 20, 2005 07:51 AM
