Honda Civic EG Automatic Transmission Removal and Installation
Old Jun 22, 2009 | 05:51 PM
Master23's Avatar
Default Honda Civic EG Automatic Transmission Removal and Installation
To see the complete article with images check it out here: Honda Civic EG Automatic Transmission Removal and Installation. Garage411.com
1. Disconnect negative and then positive battery cables, and remove battery. Remove intake hose band bolt from throttle body. Remove complete air cleaner assembly with intake hose.
2. Remove transaxle ground cables. Disconnect wire connector from lock-up control solenoid valve. Disconnect speedometer sensor connector. Remove transaxle housing mounting bolts and rear engine mounting bolt.
3. Remove transaxle drain plug and drain fluid (remove fill plug to speed draining). Install drain plug and NEW washer. Tighten plug to specification. Remove splash shields from bottom of engine and from right wheelwell.
4. Remove front exhaust header pipe and bracket. Remove cotter pin and remove lower control arm ball joint nut. Separate ball joint from lower control arm. Remove shock strut damper fork bolt and separate strut damper from fork. Remove right radius rod bolts and nut at opposite end of rod. Remove right radius rod.
When removing CV joint and drive axle assembly from transaxle, DO NOT pull on drive axle or knuckle. Inboard CV joint may separate. Pull on inboard joint.
5. Using 2 large screwdrivers, pry inboard CV joints from transaxle. Remove or support shafts aside. Protect inner CV joint spline from contamination by covering drive axle end by covering it with a plastic bag. Remove header pipe bracket, torque converter cover and shift control cable holder. Remove stopper mount. Disconnect cooler hoses at joint pipes. Using wire, support hoses aside. Remove shift control cable cover. Remove shift control cable end by removing cotter pin, control pin and control lever roller. Using wire, support cable aside.
6. Loosen lower throttle cable lock nut. Disconnect and remove throttle control cable from transaxle throttle lever. Remove front and rear engine stiffeners. Only Civic Del Sol with B16A3 engine uses a rear stiffener. Remove torque converter cover plate. Manually turn crankshaft pulley clockwise to access and remove 8 torque converter mounting bolts from torque converter drive plate.
7. Using engine hoist or an appropriate engine support fixture, relieve weight of engine from mounts. Support transaxle using transaxle jack and raise it slightly. Remove front and side mount bolts. Remove engine mounting bolts.
8. Remove all transaxle mounting bolts. Pull transaxle away from engine until it clears 14-mm guide pins on engine. Lower transaxle assembly from vehicle. Ensure torque converter remains with transaxle.
INSTALLATION
1. To install transaxle, reverse removal procedure. Inspect drive plate for cracks, elongated holes and warpage. Replace drive plate if necessary. Replace distributor "O" ring.
2. Replace 26-mm spring clips on end of each inboard CV joint splined shaft. Check shift control cable and throttle control cable operation. Adjust cables as necessary.
TORQUE SPECIFICATIONS Ft. Lbs. (N.m)
* Ball Joint-To-Knuckle Bolt: 40 (54)
* Center Beam Stiffener Bolts: 37 (50)
* Control Cable Holder (Accord): 13 (18)
* Drain Plug: 36 (50)
* Drive Plate-To-Crankshaft Bolts: 55 (74)
* Engine Stiffener Mounting Bolts: 33 (45)
* Intake Manifold Bracket Bolts: 16 (22)
* Starter Mounting Bolts: 32 (44)
* Stopper Mount
  • 10-mm Bolts: 29 (39)
  • 12-mm Bolts: 48 (65)
* Strut Damper Fork Bolt Lock Nut: 48 (65)
* Strut Damper Pinch Bolt: 32 (44)
* Transaxle-To-Engine Mounting Bolts: 44 (60)
* Wheel Lug Nuts: 81 (110)
TORQUE SPECIFICATIONS INCH Lbs. (N.m)
* Torque Converter Cover Bolts: 108 (12)
* Torque Converter Mounting Bolts: 108 (12)
meavey3368
Jul 12, 2014 11:29 PM
Master23
Jun 23, 2009 03:09 PM
ButterMule
Aug 2, 2004 04:12 PM
