anyone have ECU pin locations for b16b?
Old Aug 21, 2002 | 08:12 AM
mugen76's Avatar
Default anyone have ECU pin locations for b16b?
i have a CTR b16b motor with a b16b ecu (pct) does anyone know where i can find the pin locations for this ECU? thanks (it's because i have an IACV problem) the b16a pin locations don't work.
Old Aug 21, 2002 | 09:32 AM
kenji's Avatar
25 Year Member
Default Re: anyone have ECU pin locations for b16b? (mugen76)
I am going to assume that you are trying to put a '99-'00 CTR swap in a '99-'00 USDM Civic and you want to use the PCT ECU.
In order to make the IACV work you need to move the blk/blu wire at B8 (This location is from memory and may not be correct) to B23.
The '99-'00 SOHC Civics use a 3-wire IACV and the signal wire is located at B8. The '99-'00 DOHC VTEC Civics use a 2-wire IACV and the signal wire is at B23.
If you are trying to put a '99-'00 CTR swap in a '99-'00 USDM Civic and you want to use the PCT ECU that is what needs to be done.
-kenji
Old Aug 21, 2002 | 09:40 AM
rbf351's Avatar
Default Re: anyone have ECU pin locations for b16b? (kenji)
is that true? cause i have a 99 or 00 CTR ECU in my 00 Si and have no prblems except running a little rich
Old Aug 21, 2002 | 10:52 AM
kenji's Avatar
25 Year Member
Default Re: anyone have ECU pin locations for b16b? (rbf351)
It is true.
Notice where I said that '99-'00 DOHC VTEC Civics have the IACV signal wire at B23? Your '00 Civic Si is a '99-'00 DOHC VTEC Civic. Therefore, the IACV signal wire will be at B23 just like on the '99-'00 CTR.
-kenji
Old Aug 26, 2002 | 09:42 PM
mugen76's Avatar
kenji, i have tried b23. i ran a wire straight to the ecu. and the other to the ground. i've also tried a12, a13 and a14. still doesn't work.
Old Aug 27, 2002 | 02:34 AM
kenji's Avatar
25 Year Member
First,
What year car do you have? What are you trying to do? Please give me all details so I can base my answer off of fact.
If you have a '99-'00 Civic DX or CX you will need to move the IACV signal wire from B8 to B23. The DX and CX use a 3-wire IACV. The orange wire is no longer needed and can be eliminated (be sure to tape it off). The yel/blk wire stays intact. The only change necessary is to move the IACV signal wire. Do NOT go grounding any wires.
The answer I gave is based on the assumption that you have a '99-'00 USDM Civic DX or CX and you are wanting to run a '99-'00 CTR ECU on a DOHC VTEC B-series swap.
-kenji
Old Aug 27, 2002 | 03:11 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
damn kenji, off the hip? very informative i can barely remember what i had for breakfast....
ILoveLB
May 3, 2009 12:30 PM
EH3-R
Northern California (Sales)
Sep 21, 2007 07:00 AM
igo4bmx
May 31, 2003 05:38 PM
00ek9
Jun 15, 2002 01:35 PM
