Brake lights out indicator
Hi folks,
Lately my 1992 Accord has had the light for 'brake lights out' come on on the dash. Every time, the brake lights (all of them) are working. What could be the cause? I am a Volvo person, and in old Volvos there is a relay/sensor circuit that detects uneven voltage draw and displays a dash light if they are sufficiently uneven.
Thanks! I'm not afraid to tackle this job myself, I just have no idea where to start.
Ari
Ari
Your bulbs are most likely dual filament, are ALL of them good? If you just turn on your lights you're looking at the lower filament. On top of that what kind of bulbs are you using? LED's will trigger that response due to low resistance. If you're using an incorrect bulb then that could also trigger it.
It seems like the bulbs are working fine, but I will replace all my bulbs - I can't remember when they were changed, must have been years - and see if the problem presents itself again. In the meantime, I will check the fluid level in my MC. :O
Thanks!
Ari
Thanks!
Ari
nicolaselias
Dec 22, 2011 03:58 PM
disboiflaco
Mar 14, 2011 05:45 PM
makaveli_0000
Apr 13, 2004 09:26 AM
