honda access rear valence
Old Jun 22, 2009 | 12:17 PM
stylezDc2-3's Avatar
Default honda access rear valence
those that have the rear valence installed on their itr
i am wondering if u guy installed two way molding to install it in place
other than the screw on the bottom..
and also how is it installed properly
thnks
Old Jun 23, 2009 | 09:00 AM
BlueIntegraBoy's Avatar
Default Re: honda access rear valence
No molding needed, only the weatherstripped. There will be two bolts at the bottom, one at the rear, and two for the wheelwell, I believe (I'm on vacation, nowhere near my R).
Old Jun 23, 2009 | 12:53 PM
Tekkaboy's Avatar
This is correct.
Some people don't like to use the bolt at the rear because it leaves a visible hole if you ever take the valances off. You can drill a hole in a less visible location if you want.
spotscivic
Jul 2, 2007 06:42 PM
8atman
Jun 20, 2006 11:05 PM
