I need fiberglass repair.
Old Jun 22, 2009 | 09:00 AM
portenio78's Avatar
Default I need fiberglass repair.
Well the Del Sol has been a garage ornament since December since I am just gathering up parts for its new build. I have had the hood proped up on it kinda in a ghetto fashion, and well today it came back to biteing me in the ***. One of the mounting tabs that is fiberglassed into the hood broke loose. It looks like I can do a quick fix but I need to know what bonds good with fiber glass for me to just put the tab back in and seal it. I have no experience with glass and if I can avoid taking the hood to a body shop I will. Any ideas fellas on what I can use for a quick fix? I looked up j-b weld and it says that it bonds to fiber glass...maybe I should just try this?
Old Jun 22, 2009 | 01:14 PM
shocker911's Avatar
Default Re: I need fiberglass repair.
fiberglass loves fiberglass....fix the tab with fiberglass
Old Jun 22, 2009 | 01:41 PM
bakertime's Avatar
JB Weld is fine for small things, but for what you're talking about I wouldn't recommend it. Definitely fix with fiberglass.
Old Jun 22, 2009 | 06:38 PM
portenio78's Avatar
Maybe I will try the glass, but man the repair is only like the size of a dime and the j-b weld seems like an easy in garage fix?
Old Jun 22, 2009 | 08:21 PM
shocker911's Avatar
try it see what happenes
Old Jun 23, 2009 | 09:34 AM
bakertime's Avatar
What is the tab that broke off for? When you say mounting tab, you mean where the hood prop sits?
You're welcome to try the JB Weld, I just doubt that it's going to hold up.
Old Jun 24, 2009 | 10:54 AM
qtipp's Avatar
New User
mix up some fiberglass resin or some dyna glass to fix
Old Jun 25, 2009 | 01:37 AM
portenio78's Avatar
There is a wing nut that is molded into the fiber glass. This is what my bolt goes into. The wing nut simply busted out of the glass.
jdm_ek_noob
Jul 22, 2011 09:04 AM
SKYWALKER365
Paint and Body
May 23, 2007 06:11 AM
Hater
Nov 7, 2006 11:19 AM
InTeGrA_bLazEd
May 3, 2004 06:12 AM
B2FiNiTY
Oct 4, 2002 12:19 PM
