92 accord auto to 5spd swap problems
Old Jun 22, 2009 | 08:19 AM
fastazzf22's Avatar
Default 92 accord auto to 5spd swap problems
So I picked up this 92 accord. Ripped out the single cam and threw a jdm f22b dohc engine in along with a H23 5spd. The car was automatic. After getting everything in, tuned, touched up. I have no reverse lights. Even taking the reverse solenoid out of a 5spd trans and wiring it up in the automatic wiring harness. I still get no reverse lights. Bulbs are good. Now when I did away with the auto shifter you had to leave that plugged up and crammed under the dash and had to be in the park position for the car to start. And yes it will start in gear because the auto matic dash harness has NO hook ups for 5spd ****. I am boggled here. Failed state inspection for no reverse lights.
Also will the 5th gen exhaust fit on the 4th ?
Thanks in advance.
Old Jun 22, 2009 | 09:23 AM
92civlude's Avatar
Default Re: 92 accord auto to 5spd swap problems
From the AT selector switch in the console, 12 pin connector, yellow wire and a green/black wire. Wire these two directly to the reverse switch on the trans. Just run a 2 wires along the harness. FYI, the yellow wire should have 12v with the ig switch on.
Old Jun 22, 2009 | 11:44 AM
fastazzf22's Avatar
Problem solved.
Old Jun 22, 2009 | 01:56 PM
92civlude's Avatar
Originally Posted by fastazzf22
Problem solved.
How did you solve it? You cant leave us hanging like that!
Old Jun 22, 2009 | 02:46 PM
nus_dogg's Avatar
^^ word.
Old Jun 22, 2009 | 09:51 PM
bsivoljr's Avatar
Straight up we want the green pill man come on...
AustinDube
May 30, 2018 04:50 AM
pr0jektdc2
May 9, 2006 07:18 PM
confidence
Sep 23, 2003 09:04 PM
