Vtec NOT working~! help!
Old Jun 22, 2009 | 02:20 AM
ntoxicatedtigah's Avatar
Default Vtec NOT working~! help!
only code i am currently throwing right now is knock sensor code on my b16. i'm throwing knock code because the sensor got broken, but people have been telling me that knock wouldn't be stopping me from having vtec engage properly. Just did fresh oem rebuild. new oil/water pump, t belt, ect. . . . also this motor was good before rebuild, vtec worked fine, also we cleaned out the vtec screen.
Old Jun 22, 2009 | 03:17 AM
MHDesigns's Avatar
Default Re: Vtec NOT working~! help!
Check your speed sensor. if this isn't working properly the vtec WILL NOT kick at all until fixed.
Old Jun 22, 2009 | 03:25 AM
vikter562's Avatar
check for any shorts from the vtec oil presure sensor cables
Old Jun 22, 2009 | 07:22 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
VTEC will not engage with a broken knock sensor. get it fixed.
Old Jun 22, 2009 | 01:26 PM
i know that, and speedo works fine.
well if there was a short wouldn't i be throwing vtec code anyways. i think there are 2. pressure and spool.
hmmm, alot of people i know have gotten knock code before and still hit vtec. i was wondering, if i loaded a map onto hondata s300 and just disabled knock on there. would that alow me to hit vtec?
Old Jun 22, 2009 | 02:10 PM
Thizzed Out's Avatar
just borrow someones ECU that has the knock sensor disabled. I think thats the reason your not hitting vtec.
The factors that play into VTEC engagement:
RPMS
Oil Pressure
Knock Sensor
VTEC soleniod
Things that will STOP your VTEC:
VSS Sensor
Low Oil
Cold Engine
Taken from: The Official "Why VTEC doesn't Engage" Thread
https://honda-tech.com/forums/honda-prelude-4/official-%22why-vtec-doesnt-engage%22-thread-830163/
Old Jun 22, 2009 | 05:30 PM
ok, so i used friend hondata, tried disabled knock, still no vtec.
Old Jun 24, 2009 | 02:56 PM
ok tried a couple things , checked all wiring to vtec solenoid, power/ground. It was all fine. Now heres is what im thinking. The head was switched over from a b20/vtec setup to my b16, the reason because it had dual valve springs ect ect.. now, someone was telling me that when the head was setup for b20vtec or lsvtec they usually block some oil hole in the head. is that true? if so, i'm guessing i'm not getting oil pressure to the head, so then vtec is not wanting to work properly. my solution to this is prob getting a sandwich plate and run the oil line to head like lsvtec or b20vtec.
sonny0330
Jul 18, 2007 11:58 PM
user 72830283
Oct 16, 2005 08:24 AM
B18cHatch06
Sep 30, 2005 11:39 PM
dryhopsux13
Apr 8, 2005 06:02 AM
Raunch
Nov 8, 2003 10:05 PM
