EM1 si cluster?
Old Jun 21, 2009 | 11:04 PM
Fo-Do Fanatic's Avatar
Default EM1 si cluster?
I was watching some videos on youtube and i saw an H2B ED6 with the em1 cluster. I was wondering if any of you guys have personally done this swap and how hard it would be for it to fit? I dont mind trimming things to fit either.
Old Jun 21, 2009 | 11:13 PM
DCRB's Avatar
Default Re: EM1 si cluster?
bump for you, i'd like to know too... i've got an oem jdm CTR cluster that i'd like to use someday... that is... once i have a motor that will rev up that high. lolz
Old Jun 21, 2009 | 11:27 PM
sleepingciv's Avatar
pretty easy swap i did it, just used a dx cluster instead
Old Jun 21, 2009 | 11:37 PM
well tell me how you did it damnit!!
Old Jun 21, 2009 | 11:50 PM
http://hondacrx881.tripod.com/gsrclusterswap.html
Old Jun 22, 2009 | 12:02 AM
Originally Posted by sleepingciv
thats umm. a lot of work?
Old Jun 22, 2009 | 02:16 AM
DCRB's Avatar
wait so it's the same as wiring in an integra cluster? if so i already did that. it's not hard at all. took me about 2 hours... one to trace each wire on my old cluster to double check everything and to label stuff on the two different clusters, and another hour to cut and splice the plug in. good stuff!
edit as far as the VSS goes you DO NOT have to use one from an eg, you can use the factory one like the write up says using the speedo assy. from your old cluster, then run the corresponding wires to the correct ones on your new cluster.
Old Jun 22, 2009 | 09:13 AM
crxx's Avatar
good info
Old Jun 22, 2009 | 02:13 PM
D16SiHatch's Avatar
its really not as bad as it looks.
here's another good link:
http://www.tuner-junction.com/TJForu...88-91-crx.html
Old Jun 22, 2009 | 02:19 PM
99civicsiguy's Avatar
thats pretty cool never seen that before, i thought dx's didn't have tachs
Old Jun 22, 2009 | 02:25 PM
detuned's Avatar
my friend's dx auto had a tach i'm pretty sure..
Old Jun 22, 2009 | 03:24 PM
this is my next project a little more involved with money and stuff
Old Jun 22, 2009 | 04:26 PM
blackmugensivic's Avatar
My B16 swap that I bought from Hmotorsonline.com is a SIR 1 swap, it had an electric VSS in the tranny that I had to take out and put in my stock SI VSS, could I use the electric one that came with the motor and would it work for this cluster? Any info would help
Old Jun 22, 2009 | 04:42 PM
the electric vss will work for the cluster swap
8bluddyknuklz
Jan 25, 2010 12:30 PM
20-EM2-05
Honda Civic (2001 - 2005)
Aug 20, 2009 12:14 PM
slimjimdanny
Feb 19, 2007 06:11 PM
D-Money
Aug 7, 2006 01:21 PM
wickedEFguy
Dec 11, 2002 09:58 PM
