Problem putting back transmission on, any suggestions?
Old Jun 21, 2009 | 10:20 PM
Nathan007's Avatar
Icon6 Problem putting back transmission on, any suggestions?
I'm having some trouble putting back my transmission back to the engine..
Car is a 2001 Accord coupe 4cyl, 5spd.
I'm using a motorcycle lift to jack the tranny. I took alot of precautions trying to put it back into place, not forcing it in any way. Me and my bro managed to push it back in without forcing anything, but we got stuck with a little problem..
I've got abit less than 5mm gap all around (bellhousing to engine block), i can clear it in the front gap but not the rear.. I tried slightly tightening the bolt(s) but they have alot of resistance at about 3/4 of their way in, so i stopped there. Tries also lowering/jacking the tranny a bit but no luck..
Here are some pics;
GAP - tranny to engine block (front)
GAP - tranny to rear engine mount bracket
MISALIGNMENT - rear engine mount bracket to tranny
No matter what we tried, we couldnt get those aligned.. with what i could see, tranny dowel pins seems to be correctly in place, and nothing seems to protude between the tranny and the engine..
I'm kind of lost..Anyone has suggestions?
Old Jun 21, 2009 | 10:24 PM
h22 kid's Avatar
Default Re: Problem putting back transmission on, any suggestions?
what if you try just bolting it into the block and maybe that can help... could be the pins arent able to slide in all the way or something... maybe worth a shot or not
Old Jun 22, 2009 | 03:01 AM
hondamark35's Avatar
that's not too big of a gap to pull up with the bolts.. you just need to get those holes aligned. try a big pry bar on that rear "T" mount, and try lifting the motor slightly, maybe with a trolly jack or a strong friend.
give it a good shake too... sometimes it will just slide into place.
hope that helps.
Old Jun 22, 2009 | 06:03 AM
Nathan007's Avatar
thanks guys! ill give it a try
Nathan007
Transmission & Drivetrain
Jun 22, 2009 11:15 AM
truplayaz24
Welding / Fabrication
14
Oct 17, 2007 10:02 AM
K-Spec
Jun 12, 2006 08:54 AM
coot_er
Dec 24, 2005 03:46 AM
Rob_Dog
Nov 13, 2004 10:44 PM
