How many watts can i run safetly
Old Jun 21, 2009 | 10:03 PM
deerman2701's Avatar
Default How many watts can i run safetly
How many watts can i run on my audio system with all stock components
Old Jun 22, 2009 | 07:04 AM
98civdx's Avatar
Master Detailer
Default Re: How many watts can i run safetly
if you put a amp youll blow them, and even with a aftermarket deck, if you turn them up really loud you will be pushing them.
i say no more then 15-20 watts.
Old Jun 22, 2009 | 08:00 AM
Ok would i be safe running 1200 rms off an amp and two kicker l5
Old Jun 22, 2009 | 08:16 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Your pushing your stock charging system on your car. I would not run more then that for a full system. Your amps will not make the power needed because there is not enough amps from the alternator.
Old Jun 22, 2009 | 09:39 PM
98civdx's Avatar
Master Detailer
if you upgrade you battery,
have your alt checked with the amp turned on as loud as you can. if the alt is good then yes but dont be suprised if its not.
im curently runing a sony 1000 watt 2 channle and a 400rms 4 channle, and i 0 problems. with a stock alt and a upgraded battery.
Old Jun 23, 2009 | 05:40 AM
fcm's Avatar
fcm
Old Fart
What do you mean by "stock components"?
If you mean stock charging system, [alt., batt.] then it will depend on how loud and how long you want to play the system.
I always recommend an alt. upgrade when installing 500W RMS or more, it takes about 75A of current to produce 500W RMS, [about 175A to produce 1200W RMS]. 94
Old Jun 23, 2009 | 06:51 AM
dohcvtak's Avatar
i have a 170a alternator and still show signs @ 1200w rms
Old Jun 23, 2009 | 05:13 PM
fcm's Avatar
fcm
Old Fart
"signs"? 94
Old Jun 23, 2009 | 07:16 PM
James777's Avatar
make sure you upgrade your stock ground wires under the hood. upgrading your battery isn't a bad idea, either, but you can wait until the one you have now quits. you're gonna want to use 1/0 gauge wire, too.
James Stanton
Old Jun 23, 2009 | 07:17 PM
James777's Avatar
btw, music is dynamic, so your not putting a constant load on your electrical system.
James Stanton
Old Jun 24, 2009 | 01:12 AM
James Stanton
That goes out the window when I want to pound my system and it sounds like poo or what it should sound like if it was done right. Or someone with a well built system with half the money and stuff I have beats on me with a well planned system. Who cares if it plays. Does it play right is the question.
LadyCivic91
Mar 13, 2013 01:01 PM
chillerice
Audio / Security / Video
12
Feb 9, 2013 07:32 PM
Rednas
Mar 1, 2008 07:45 AM
MilanoCivic97
Mar 12, 2007 11:36 AM
CrazyModGSR
May 8, 2006 04:38 PM
