How to measure the crankshaft stroke?
Old Jun 21, 2009 | 09:37 PM
Wytek9's Avatar
Default How to measure the crankshaft stroke?
Can anyone teach me how to measure the crankshaft stroke of ITR/GSR crankshaft using bernier caliper, because someone is selling GSR crankshaft and i need to know if it is really came from GSR which is 87mm stroke. Thank you..
Old Jun 22, 2009 | 07:29 AM
ruffrhyder's Avatar
Default Re: How to measure the crankshaft stroke?
Measure the distance between crank and rod centerline, then double the distance measured.
Old Jun 22, 2009 | 04:36 PM
DonF's Avatar
Easiest way is rod journal width. Gsr, R and B16B are the same. LS, B16 are wider. The other way is piston TDC to BDC with a vernier.
80 dolla crx hf
May 2, 2009 09:37 AM
KilaB18C
Oct 21, 2004 08:03 AM
JDMlyfestyle
Jun 14, 2004 01:06 PM
ill phil
Feb 4, 2003 07:18 AM
