FS civic96-00 coupe parts some b series
Im located in miami 4 now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
everything is obo so make an offer support the build
ek skunk2 camber kit front 75 800 miles
ek rear drum ss brake lines 30
ls fuel rail 6an adapter 20
b series half shaft 35
LS block + crank + oil pick up jus needs hone $80 or b16 bare block
LS water pump brand new $45 or 110 for block with water pump
3 wiseco high comp pistons light use $40 P/N 6567m845 0405a 84mm
fuel pressure gauge and 6an adapter $45 like new
block gaurd b series $30
ls vtec dowel pins $20
rear glass panel coupe $20
lr panel $20
rr panel $20
fl piler panel $15 small hole from gauge pod screw
fr piler panel $15
stock driver side motor mount like new $20
rear bracket motor mount like new $15
ac bracket bseries $20
Trunk lid support $25
Trunk lid with si spoiler $30(trunk olny) Sold spoiler
LS drivers side engine bracket $10
Trans torqe mount $10
charcoal can civic 96-00 coupe $35
lr panel $20
rr panel $20
fr piler panel $15
LongBeachEP3
May 16, 2007 12:21 AM
LongBeachEP3
May 9, 2007 08:37 AM
