rebuild burning a quart a week
Old Jun 21, 2009 | 04:33 PM
j0keefe21's Avatar
Default rebuild burning a quart a week
hi i just did new rings and rod bearings on my d15 bottom end. once put all back together it was blowing plent of smoke under load and burning alot of oil. i compression tested the motor and got 200 210 205 200. only thing i can think of is the expander on the oil rings looked a tad small and wouldnt butt. i checked ring gap on all the rings and it was good. the oil rings werent marked so i figured they were unidirectional. i oil pressure tested the motor and it was good also. any ideas would be great thanks guys
Old Jun 21, 2009 | 04:40 PM
NACvicSi's Avatar
Default Re: rebuild burning a quart a week
what did the walls look like? Maybe you aren't getting a good seat.
Old Jun 21, 2009 | 04:50 PM
j0keefe21's Avatar
they looked decent. still could kind of see the cross hatch on them. either way i got new oil rings on the way and am going to hone them b4 the new rings go in. i just hope thats the problem. idk if this matters but at first when i saw the smoke i pulled the plugs and only one had oil on it then progressively they all got that way. i just know its a **** ton of oil. also i heard that when you stick your hand over that oil fill cap when its running you should feel air rumbling. i do... so possibly a head problem?
Old Jun 22, 2009 | 10:02 AM
j0keefe21's Avatar
bump
Old Jun 22, 2009 | 10:12 AM
98civdx's Avatar
Master Detailer
what about valve seals?
Old Jun 22, 2009 | 10:24 AM
j0keefe21's Avatar
thats possible but the head wasnt messed with much. and i just dont see how they would all go like that all of a sudden.
Old Jun 22, 2009 | 10:25 AM
98civdx's Avatar
Master Detailer
well they was it burning any oil before the rebuild? they could have been bad or going bad the whole time.
Old Jun 22, 2009 | 02:01 PM
j0keefe21's Avatar
it wasnt burning practically any oil but compression tested low so i went with new rings and did rod bearings while i was in there.
Old Jun 22, 2009 | 02:08 PM
98civdx's Avatar
Master Detailer
oh. replace the oil rings and hone it.
then while your in there check the other gaps just to make sure.
Old Jun 22, 2009 | 02:58 PM
j0keefe21's Avatar
alright thanks that was the plan but making sure its not something simple i was over looking b4 i tore it apart. also if i open my oil fill hole to put oil in smoke comes out which obviously is bad. but my oil is all burnt so im assuming from that. same with my spark plugs when i take them out a little smoke comes with it.
Old Jun 22, 2009 | 03:04 PM
Pothole987's Avatar
test/replace the PVC valve. i've seen some stick and well, its A CLOUD OF SMOKE.
Old Jun 22, 2009 | 04:20 PM
j0keefe21's Avatar
that wouldnt explain my loss of oil would it?
FireInTheHead
Nov 4, 2014 04:15 PM
joss731
Sep 15, 2010 08:50 AM
SiR Inspired ED7
15
Jul 31, 2007 05:19 PM
jtracing919
Jan 25, 2006 05:06 PM
