WTF is this plastic piece on the thermostat housing ?? Y8 99
Old Jun 21, 2009 | 04:07 PM
dxcivicsi's Avatar
Default WTF is this plastic piece on the thermostat housing ?? Y8 99
http://m626.photobucket.com/albumvie...DCO213tw%3D%3D Like WTF is this **** and where do the hoses go coming off of it
Old Jun 21, 2009 | 04:20 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: WTF is this plastic piece on the thermostat housing ?? Y8 99
Thermo switch...tells the rad fan to turn on
Old Jun 21, 2009 | 04:27 PM
dxcivicsi's Avatar
No I know that I'm talking about that black tee thing !?!?
Old Jun 21, 2009 | 05:12 PM
ek-g6's Avatar
Looks foreign or homemade, but also looks like a bleeder valve.
Old Jun 21, 2009 | 05:40 PM
dxcivicsi's Avatar
Ya it's foriegn to all y8 before 99 and 2000 it's only on those two years saw another at the wrecker but I can't find anything about it
Old Jun 22, 2009 | 08:04 AM
dxcivicsi's Avatar
Any one please with a 99 or 2000 y8 take a pic of that plastic tee or tell what it is I don't want to put a coolant hose where it doesn't belong again..... Bitch to empty out coolant from IM and combustion chamber lucky I didn't hydrolock so pls if someone knows anything about that tee thing, coolant or vaccum? Or wtf
Old Jun 22, 2009 | 11:42 AM
civic_driver's Avatar
I don't know if that thing comes with the car or not but if not, you can probably replace it with a stock part and not plug it anywhere. It depends on what it is.
Old Jun 22, 2009 | 01:11 PM
dxcivicsi's Avatar
it does come with the car but its only on y8's of 99 and 2000, so its not aftermarket. but still dont know if its a vaccum or coolant thing ahh
Old Jun 22, 2009 | 01:20 PM
Former User's Avatar
You mean this?
Old Jun 22, 2009 | 02:11 PM
Marauder's Avatar
Yes, its for the air-injection. The side nipple you need a hose to connect to the air intake, after the air filter. The top nipple you run a hose to the intake manifold.
Old Jun 22, 2009 | 02:44 PM
I don't think that's the part. His is located on the thermostat housing and not on the intake manifold.
Old Jun 22, 2009 | 02:47 PM
Marauder's Avatar
Yes, that is the part. The air-injection is only turned on for cold-start. That plastic part is a thermal switch. It will only allow the air to flow into the intake manfiold, and then to the fuel injectors, when the engine is cold.
Old Jun 22, 2009 | 02:51 PM
Oh, you mean the control valve itself is located on the thermostat housing? That makes sense. If that's the case, I stand corrected.
Btw, why does this control valve exist? Why didn't they just use the computer to check the coolant temperature and then based on that open the IACV valve when the car is cold? Why do you have to have a two parts when you a single one can do both jobs with a simple check in the computer?
Old Jun 22, 2009 | 05:04 PM
Marauder's Avatar
I'm not sure why they went ahead with that design. Probably a cost savings to make the mechanical thermal switch than to incorporate a logic control one, and they don't have to do any ecu programing for it.
IMO...not sure why they had to add that POS emissions device for just the 99-00 y8 engines
Old Jun 22, 2009 | 10:05 PM
dxcivicsi's Avatar
Omg dude I love u thanks !!!!!! I'll have ur babies anyday finally **** I put a coolant hose on the nipple on the IM that's how I got coolant everywhere but thanks again Dude !!!!! I love Honda tech it's ppl like u that prevent virgin swappers from efffing up **** I almost was gonna rip that **** off lol I was so pissed and the manual I'm using is specific enough lol
Old Jun 23, 2009 | 01:26 AM
wudini's Avatar
get yourself a Helms manual if you don't already have one. if you need, PM me i'll send you it.
dxcivicsi
15
Jun 24, 2009 08:24 PM
kylea24
May 25, 2009 07:45 AM
uo959
Jan 15, 2008 07:55 PM
kamaleon
Oct 3, 2003 03:12 PM
