CRX Si road racer F/S
1990 CRX Si fresh from a ground up rebuild 1 month ago, no DNF's with proven history of podium finishes with current log. located in Ohio. built 2001, car includes:
MOTOR:
fresh motor
header
new exhaust
cold air intake
new vac lines
comp clutch
new radiator
all new hardware
with fresh coat of paint, inside and out
very reliable
INTERIOR:
completely gutted and painted
custom weld in cage (one of the best i have seen)
gauge cluster (autometer)/ liquid filled oil pressure, water temp, air fuel meter, fuel pressure digital readout gauge
push button start and accessory panel
wink mirror
wired for radios w/ PTT button
momo steering wheel
momo race seat (black)
diamond plate footwell
aftermarket pedals
scraped clean of sound material
SUSPENSION:
scrapped wheel wells
AGX adjustable shocks
coilovers
ES bushings in all including rear lower control arm
everything has been sanded and painted
new hardware front / rear
suspension tech sway bars f/r
lower tie bar rear
upper strut bar front (DC sports)
BRAKES:
front / rear disc
braided line front / rear
new pads
new rotors
new rear calipers
synthetic fluids
new brake master
no leaks
EXTERIOR:
new paint
new molding
front air dam
glass is perfect
SPARES PACKAGE:
spare motor (strong)
trans w/ LSD
wrapped header
exhaust
all new suspension front and rear, some w/ ES bushings
braided brake lines (used one time) f/r
2 set of front calipers
2 set of rotors slightly used
4 AGX adjustable shocks w/ coilovrs
2 sets springs / various rates
2 front bilstein shocks w/ coils
1 wink mirror
cobra imola 2 seat FIA approved( brand new )
front suspension tech swaybar
neuspeed lower bar rear
neuspeed front upper strut bar
radiator w/ fan
lights / bumbers / fenders
12 wheels and tires / used
1 set rains mounted NEW
1 set intermediate rains not mounted NEW
20 used KUMHO tires
1 set 15" momo wheels w/ tires
14 used 15" kumho tires
brake master
cases of synthetic oil
gas can, funnels
tons of brake pads
MUCH MUCH MORE..to much to list
car has never been bent..no rust..only 80K on body and in perfect shape. complete turn key package ready to go racing. pictures available upon request. well sorted and well taken care of. let's talk...can negotiate spares package. $9800.00 for all
e-mail me with any questions
MOTOR:
fresh motor
header
new exhaust
cold air intake
new vac lines
comp clutch
new radiator
all new hardware
very reliable
INTERIOR:
wink mirror
momo steering wheel
aftermarket pedals
SUSPENSION:
coilovers
lower tie bar rear
BRAKES:
front / rear disc
new pads
new rotors
new rear calipers
synthetic fluids
new brake master
no leaks
EXTERIOR:
new paint
new molding
front air dam
glass is perfect
SPARES PACKAGE:
trans w/ LSD
wrapped header
exhaust
1 wink mirror
radiator w/ fan
20 used KUMHO tires
brake master
gas can, funnels
tons of brake pads
if the AGX's are compatible with a 91 civic hatch std I would buy 4 off of you
Also what tranny w/lsd is in your spares package
This of course depends if you want to part some stuff out
Thanks
Thanks
