NO START SWAP PROBLEMS!!! HELP!!!
Old Jun 21, 2009 | 02:02 PM
mayfly's Avatar
Icon2 NO START SWAP PROBLEMS!!! HELP!!!
Hey whats up HT, ok so i swap a d15b7 into my 1990 si hatch, it cranks and seems like it wants to start but doesn't, i smell fuel so i think i must be gettin fuel, im wondering if the spark plugs aren't firing? when i pulled the plugs they had oil on them, but is that from adding oil? any ideas? the battery is new and since its cranking i must be getting a good ground. help, or hit me up on AIM hamie916 if thats easier, thanks
Old Jun 21, 2009 | 02:29 PM
mayfly's Avatar
Default Re: NO START SWAP PROBLEMS!!! HELP!!!
anyone?
Old Jun 21, 2009 | 02:53 PM
mayfly's Avatar
also can someone help I.D. this cable thing. it seems to run up into the cluster? and it hangs out in the engine bay, but i can't seem to find out where it goes.
Old Jun 21, 2009 | 03:00 PM
crxblues's Avatar
timing good? that cable looks like the speedometer cable. goes from the franny to the back of the cluster. actually it looks like the cluch cable
Old Jun 21, 2009 | 03:09 PM
mayfly's Avatar
na not the clutch cable, to small and i have the clutch cable set up. if it is the speedometer then where about in the tranny does it plug in?
Anton LaVey's Avatar
how would there be oil on the plugs from adding oil thats the stupidest thing i ever herd, unless you you poured oil in there
Old Jun 21, 2009 | 03:11 PM
mayfly's Avatar
i know it sounds stupid, and i pored it in from the top at the valve cover,but i dont know why there is oil on the spark plugs, wish i did know, but any ideas on why its not firing?
Old Jun 21, 2009 | 03:12 PM
BiG ChOr!Zo's Avatar
get this man a helms manual
Old Jun 21, 2009 | 03:20 PM
mayfly's Avatar
i got a manuel. i was trying to figure out in the book what that cable/line was but i couldn't. seriously though can anyone help?
Old Jun 21, 2009 | 04:15 PM
if there is oil on the plugs it wont start
Old Jun 21, 2009 | 04:21 PM
mayfly's Avatar
i cleaned the plugs. would it be ok to put a little gas into each cylinder and try to start it? or would the make things worse?
Old Jun 21, 2009 | 07:35 PM
mayfly's Avatar
still looking for help. but i think maybe the timing could be off. any ideas?
nexgen91
26
Nov 14, 2014 09:28 PM
johnnyonth3spot
Jun 22, 2008 11:24 AM
mahatma
Aug 12, 2006 08:20 AM
Jonknee
Jun 1, 2006 08:38 PM
drjondurst
Mar 29, 2003 06:34 PM
