timing belt replacement/other maintenence?
Old Jun 21, 2009 | 01:14 PM
skunk2FTMFW's Avatar
Default timing belt replacement/other maintenence?
i just recently fell out of love with mitsubishi, and decided to get a 2000 ls back in april(116k miles). the problem is that idk anything about honda/acura and i was just wondering what my new beast might need to have done to be kept in tip top shape..?
thanks phrends.
Old Jun 21, 2009 | 01:24 PM
1992blueGSR's Avatar
Default Re: timing belt replacement/other maintenence?
if you wanna do the timing belt:
then get the belt, water pump, and cam seals all at the same time, that way that side of your motor is good to go.
other than that, plugs, wires, ignitor, gaskets, ect, ect.
its got pretty decent low miles so it shouldn't need too much, unless its had the **** beaten out of it.
Old Jun 21, 2009 | 02:50 PM
nsxtasy's Avatar
H-T Order of Merit
Look in the owner's manual for your car. You'll find the recommended intervals for various services in the maintenance schedule there.
If you work on your own car you will also want a service manual for it. You can buy the service manual for your car (as well as the owner's manual, if it's missing) here.
smillion
Honda Civic (2001 - 2005)
Feb 14, 2014 12:25 PM
utn
May 14, 2008 08:35 PM
digitalh3lix
Nov 13, 2004 10:54 PM
AmberDi
Jun 14, 2004 04:07 PM
dragontegz
May 8, 2003 07:56 AM
