TRUNK LEAK.. and its raining all week..
Old Jun 21, 2009 | 10:12 AM
teggy_617's Avatar
Default TRUNK LEAK.. and its raining all week..
for some reason my trunk got a puddle of water in the spare tire area.. i was thinking of the light gasket cause when i swap my 97 tail light to a 99 i forgot. so i take it out and put it back. and the next day i can see water building up.. and i notice there water in my tail light when i open the trunk... is it the weather strip from outside or do i need to seal it? and if to seal it do i seal it from the oustide when the trunk is close. or do i take the TAIL LIGHT out.. and what kind of seal should i buy and where. please help cause it gonna rain all week! ahhhh
picture would be nice.. THANK YOU
Old Jun 21, 2009 | 11:16 AM
ek-g6's Avatar
Default Re: TRUNK LEAK.. and its raining all week..
is the taillight gasket still good? Is it ripped or anything like that? If it's not that it maybe coming from the antenna? If it is the gasket, I have used weather stripping bought from walmart n made my own gasket, but if you don't want to go that cheap route, you can always go to the Honda or acura dealership n get some new ones.
Old Jun 21, 2009 | 11:57 AM
echoside's Avatar
I had a water leak in my 99 hatch and it was the vents under the back bumper cover. I'm not sure if the vents are there in a coupe or sedan but I would assume they are. You can see if it's them by removing the plastic panels, they are below the taillights. I just got some caulking and sealed around them. Of course you said there is water in your tail lights so it probably isn't the vents but it's worth a check.
Old Jun 21, 2009 | 12:03 PM
teggy_617's Avatar
how do u upload picture cause i got some i wanna post..
Old Jun 21, 2009 | 12:13 PM
teggy_617's Avatar
quick question .. i didnt remove the gasket so i might put it back wrong.. where the gasket located? is it when u unscrew the screw and it right there? or is it when u remove the tail light and it there.... and what about silicone.
Old Jun 21, 2009 | 03:12 PM
ek-g6's Avatar
IT all depends did it stick to the body of the car, or stayed on the taillight themselves? Its a black spongy material. Looks like picture below and its the thing thats being pulled up.
Old Jun 21, 2009 | 05:38 PM
teggy_617's Avatar
first of all i have a 97 4dr integra..
i found out that there no gasket on the passenger INNER tail light.and my outter gasket both look not in good condition .. should i buy new gasket? or silicone it. where can i buy the gasket beside dealership..
Old Jun 21, 2009 | 05:44 PM
ek-g6's Avatar
I know that isnt the correct make and model of tailights, but i was trying to give you an idea of how the gasket would like. Other than the dealership, im guessing ebay, or search it on google, your can try silicone, but if you need to take it out later, it might be pain.
Old Jun 21, 2009 | 06:10 PM
teggy_617's Avatar
oh yeah i know it different my bad if it came out kinda rude LOL.. i just found a site. it around 15 a piece. so ima order 2 outter gasket for both side and 1 inner gasket. hopefully this stop, so that i can finally make a board for my trunk heh
Old Jun 22, 2009 | 11:13 AM
teggy_617's Avatar
damn another problem i think my antenna is leaking. cause it a puddle right at that spot. how can i fix this also.. feel like my trunk is leaking in a lot of way ahh
ps. it a 4 dr
ordering 2 outter gasket and 1 inner gasket so far*
Old Jun 22, 2009 | 11:24 AM
ek-g6's Avatar
If its the antenna, the drainage tube may have come out of place. if you remove the driver side trunk panels, you will see it, its a clear tube.
Old Jun 22, 2009 | 11:29 AM
itslogz's Avatar
Heres what you do... This is what I did to find my trunk leak.
Get IN the trunk while its raining really hard, and pull all the rear panels out. Look with a flashlight closely. I was getting puddles in my trunk, and found a small pinhole leak in the very back left corner of the car around the seam sealer. Got some more seam sealer once the rain stopped and the car was completely dryed back out with towels/etc and no more leaks. The car had a dent that went onto the inside of the taillight hole area that had broken a piece of the seam sealer open.
GL. Replace that gasket if thats all it is, there like $20 from Acura.
Old Jun 22, 2009 | 01:05 PM
charbars's Avatar
i had a trunk leak in my da and it ended up being the from the new taillights i had put in.. threw the stock lights back on and no more leak
Old Jun 22, 2009 | 05:14 PM
teggy_617's Avatar
so far it the right inner gasket. and two outer gasket and the antenna section but the tube is connected tho.. and it not the sunroof tube either.. well waiting for the gasket to come home and see how is it.. suck *** cause it gonna rain all week still. ahh
Old Jun 22, 2009 | 05:36 PM
ek-g6's Avatar
maybe rubber grommet on the antenna mast might be broken or ripped.
Old Nov 10, 2012 | 08:50 PM
panamacharley's Avatar
I tried silicone sealing the tail light gasket. No help
Old Dec 29, 2012 | 06:02 PM
BigGuy's Avatar
Mine leaks in the trunk when its stationary. Im annoyed because its recently started and i cant bloody find it. i have re-aligned and sealed my taillights, put expanding foam between the rear quarter panels which also deadens vibrations. i have cleaned out the drain away for the sunroof and the fender vents. i do have to check the mid section of the sunroof drain away but i am stumped at how to remove the interior trim to gain access to it. Besides, I live and breath in England and the rain is ******* me off for over 4 months now. I have an eg saloon 1994
gerdaland
Honda Civic (2001 - 2005)
10
Dec 30, 2008 07:06 PM
sil04ver
Nov 18, 2008 06:35 AM
Cuong-nutz
Feb 24, 2005 05:16 AM
.ShawnD.
Apr 26, 2004 10:33 AM
crewjones
Feb 15, 2004 02:32 PM
