need help guys my teg broke on me
first of all my teg is slammed
and I was at walmart yesterday and as I was about to leave the teg hit a pot hole and then just turned right off
I parked the teg by pushing it to a parking spot
and then saw that my oxegen senser wires were ripped, they were just hanging there on the ground
so I jacked the car up with my spare jack and just connected the wires again
but then the car still wouldn't start
it would just turn over but no start
that night I came back with some friends and we started checking what we could do right
we found out that my engine wasn't getting any gas
but thats all we found out
do you guy's think it's a fuse or if I broke my fual pump in the pot hole?
thanks for the help guys
Seeing that you already ripped your o2 sensor wires, it leads me to believe that you may have ripped the wires for your fuel pump. I would investigate your problem more. And for god sakes, DO NOT get under your car using the scissor jack supplied with your car.
not the wires for the fuel pump cause they do not run outside the car they run along the inside and exit under the back seat in order to tear those wires with a pot hole it would have to rip the fuel tank off
lol, thats why the scissor jack is called the widow maker. but yeah, try checking the main relay, and the main relay, and the fuel pump relay.
I got some help from a few honda guys today
the fuse to my ecu blew out when the wires on my oxegen senser ripped off i'm guessing
we changed the fuse to the ecu and bamm!! the fual pump turned on and the car started right up, haha I was like yeeessssss my baby not broken no more
I taped up the wires to my senser and tucked them in nicely so that they wouldn't hit the floor anymore and then used some good old zipties just to be on the safe side
It is possible for you to rip the wires apart for your fuel pump. Case in point, driving to my mother-in-laws house, hit a pothole, car dies. WTF!!!! I check while waiting for the tow truck driver the following; timing belt, air, and spark. I notice there is no fuel smell after many attempts to start it. Get it home, test the wires to the pump, saw that the wires had snapped where they leave the body and go into the tank. Said screw it, replaced the wiring and the fuel pump seeing I had already dropped the tank. So, yes, it is possible.
90teg91hatch
Jun 16, 2008 12:25 PM
