LS transmission oil
Old Jun 21, 2009 | 08:39 AM
inaety's Avatar
Default LS transmission oil
I have a 99 Si with an integra LS transmission (don't ask me why), and I am trying to change the fluid. I know how and everything, but I picked up two crush washers from honda for a b16 transmission, and wanted to make sure that they will fit. Also, will two quarts of MTF be enough? Thank you
Also, can't I just remove all the fluid, put both bolts back in, lower the car, and then put the fluid in where the Vehicle Speed Sensor plugs into, and drive away?
Old Jun 21, 2009 | 09:18 AM
inaety's Avatar
Default Re: LS transmission oil
bumpp
Old Jun 21, 2009 | 09:29 AM
Spike-EG8's Avatar
The fill plug is by the passengers side drive shaft, and it's like just under 2L of 5W30 engine oil that you put in.
Old Jun 21, 2009 | 09:34 AM
inaety's Avatar
I heard its 2.3 for integras. Are you sure?
Old Jun 21, 2009 | 02:57 PM
unusual71's Avatar
i put about 1.75L or so before the oil started coming out of the check hole
AdRoz
Transmission & Drivetrain
Jun 14, 2010 10:36 AM
pnoytypeR
Feb 6, 2008 09:29 AM
H 20two 4 Me
Aug 24, 2006 02:46 PM
brian3676
May 8, 2006 09:17 PM
