Nokya light bulb question
So Id like to put some hyper yellow nokya bulbs in my corner lights and my headlights. I have a 91 accord. So here are my questions. First the corner lights, there are two bulbs. Do i need to do both? So all 4? Next the headlight. I want to do the high beams. Do I need to order ones that say for "high beams"? All the bulbs I found on e-bay say for low beams. Will those fit in the corners and work for the high beams? Thanks for any response.
low beams are 9006
high beams are 9005
you can do all 4 corner is you want, on each side, one bulb is for when you turn the lights on, and the other is the blinker.
high beams are 9005
The corner bulbs part number is 194 or 168, same kind of little peanut looking bulbs. Then if you are gonna change the bottom bumper lens bulbs, those are larger, just check out
http://www.sylvania.com/ConsumerProd...lacementGuide/
GSblueRacing
Feb 12, 2003 10:11 AM
