Clutch and flywheel torque specs
Old Jun 20, 2009 | 07:44 PM
danthemang3's Avatar
Default Clutch and flywheel torque specs
So I'm doing a k20z1 swap on my integra and just bought a exedy clutch and flywheel. I just need to know what the torque specs are and if they rec. replacing the pressure plate bolts. I have a helms for my integra but not the rsx. Thanks in advance.
Old Jun 20, 2009 | 08:19 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Clutch and flywheel torque specs
Well for mine I used red loctite and around 150lbs on the flywheel but only around 55lbs on the pressure plate with blue loctite
Old Jun 20, 2009 | 11:37 PM
hawaiiancb74's Avatar
90# with NO! loctite for the flywheel
19# with NO! loctite for the pressure plate
never ever ever ever ever ever use loctite on these components, never ever over torque them either, if you do youll never get them off again, the bolts on the flywheel are hard enough to get off alone.. there is no mention of using a loctite in the helms either for this exact reason.
t0p_sh0tta
Jun 9, 2014 10:35 AM
TeinEM2
Aug 4, 2011 07:38 AM
2wheelhunter
Sep 12, 2006 09:36 AM
b18bVtecRS
Aug 24, 2004 03:42 PM
CrxSi707
Aug 27, 2003 05:00 PM
