jun cams with stock 10:1 comp.
hi, i have a 98 gsr and i was wondering which stage jun cams would work best with my stock compression? im asking in the itr forum cause you guys seem to use the jun cams more than the rest of the people on this board. any help will be appreciated. thanks
I run 11.5 compression with my Jun 3's I would assume the less agressive the cam profile the less compression you need to run them. (Therefore go with Jun2's or 1's if the exist.)
Get the 3's, you can always upgrade your pistons later. No point in going with the less aggressive cams.
