Do I need a new distributor?
Old Jun 20, 2009 | 09:16 AM
teggyhill's Avatar
Default Do I need a new distributor?
Hey guys I had a question for my 94 gsr. In first and second gear when im just coasting through the neighborhood or looking for a parking spot at work the car kinda jumps back and forth till I push the gas in more than I already am. My friend told me i might need a new distributor is that true? Or is it something else? Hope you guys can help thanks in advance!
Old Jun 20, 2009 | 03:15 PM
jonnybadboi9's Avatar
Default Re: Do I need a new distributor?
How old is the engine? MILES? On my 94 ls i had a problem like that... id b driving and then id shift n then it would jump bak n forth too. I took everything apart after doing diagnostics with it and found that it was my water pump. The A****** who had the engine b4 put too much silicone gasket seal around the edges and it broke off, and stopped the water pump from turning.
Get multimeter and check spark tho, check ignition coil, spark plug wires, and main relay as well. Goodluck.
Old Jun 20, 2009 | 04:52 PM
teggyhill's Avatar
sorry for not leaving all that info. yeah its the original motor its got 165k i just changed the waterpump timmingbelt and spark plugs maybe 3 weeks ago.so its not my distributor?
Old Jun 20, 2009 | 05:02 PM
ek-g6's Avatar
I had a similar experience, but turned out to be clutch, it just wasnt grabbing, and finally went out, then i changed out the clutch and never had that problem again. If it is the distributor, i dont think it would be the "WHOLE" distributor, but rather than one the components, i.e. control module, ignition, or even cap, or rotor. hope it helps a bit.
Old Jun 23, 2009 | 11:10 AM
em1si's Avatar
bump...i've got a similar problem on my 90 teg...
i was thinkin either the distributor or the injectors being dirty...
did u find out what was causing the jerking while driving?
btw, if one of the components of the dizzy went bad other than the cap or rotor, do u have to replace the whole dizzy?
sorta2
11
Jan 14, 2012 05:23 PM
jmacsss
Nov 8, 2011 05:09 PM
CivicGirl94
11
Dec 21, 2008 04:35 PM
951dc5
Jun 8, 2005 01:31 PM
aftergamex
Nov 12, 2004 05:37 AM
