A/c Question
My ac slowly stopped working ( never worked great )
So i decided to re-fill the freon, when i filled it it worked for a few minutes then a whining came from under the passager dash. Does this part need to be replaced or could there just be air in the system
Air and moisture don't mix well with refrigerant in an A/C system. If the system was completely empty of refrigerant due to a major leak, then you must first fix the leak, evacuate the system, and then recharge the system to achieve the proper refrigerant pressures on the low and high sides.
chikin pickle
Apr 28, 2013 06:45 AM
