ys1 tans in gsr 94 teg, what clutch and helical
i have a 94 gsr with a ys1 trans. the clutch is set up hydrolic with the brack for the cable. a slave cylinder mounts underneath the cable bracket pushing the cable bracket upwards. is this the way the 94 gsr came or is this aftermarket. im looking to buy a clutch and a obx helical, but do not know if i buy as 94-01 teg or as b16a trans cause i know they also used a ys1. i was told there are actually three different ys1's with no way of telling them apart other then counting teeth. If you could please help with letting me know when i order parts, what do i order parts as ( year, make, model) as you can see in the picture the bolt going down threads into the slave cylinder
marcin
Jun 26, 2006 05:08 AM
