Really bad sputter, then spark!
Old Jun 19, 2009 | 11:00 AM
skipbudlong's Avatar
Default Really bad sputter, then spark!
Everytime I go to turn on the hatch it sputters first then it turns on like nothing. ONly on cold starts. Then if i drive around for awhile and try to turn it on again it'll crank and then die. IM thinking its not getting fuel, but from where? And when I drive on the freeway, crusing at 75 at 3200-3500 the car feels like it surges, like it needs fuel. A little gas fixes it though. Sir b16a by the way.
Old Jun 19, 2009 | 11:12 AM
dephtone's Avatar
Default Re: Really bad sputter, then spark!
Check Engine Light on? Which ECU are you running?
Old Jun 19, 2009 | 11:21 AM
No CEL. Im not sure. But I think its the pw0. Thats the ecu that came with the b16 right?
Old Jun 19, 2009 | 11:48 AM
dephtone's Avatar
pw0 or pr3. You may want to check to make sure.
An easy way to check to see if you are getting fuel is to pull the return line off the bottom of the fuel pressure regulator and turn the key to the on position and see if fuel comes gushing out, you know you have fuel. You may want to check with another main relay under the dash.
Old Jun 19, 2009 | 12:06 PM
I know I am getting fuel. Which is why the car turns on. IM just wondering why it always hesistates. It turns on all the time just with that weird sputter in the beggining. And if Im crusing around 3200-3500 rpm it'll feel like its missing until I give it gas. Then it feels normal. Any insights?
Old Jun 19, 2009 | 12:27 PM
Creator's Avatar
Check the distributor, or the main relay. Sounds more like a distributor problem though
Old Jun 19, 2009 | 02:53 PM
Well I changed the cap, cables, plugs. I wanted to put in a rotor but am having problems taking out that little screw. Its threaded.
Old Jun 19, 2009 | 04:34 PM
dephtone's Avatar
Well I was seeing if it was possible the fuel pump might be cutting out.
Are you getting a strong spark in each cylinder? Have you checked the timing to ensure it's correct?
Old Jun 19, 2009 | 06:03 PM
sh!ft's Avatar
Who the fack changed my title?!
for some reason im having the same problem, brand new dizzy and coil/cap/rotor. and the car sputters when im on take off and it almost catches when i start her up and i gotta put the gas on to get her running. thinking its my timing. ionno
Old Jun 25, 2009 | 11:20 AM
When im in 3rd around 3000 rpms it feels like it struggles, until I give it gas. Then it feels like i just hit vtec. What is that?
Christopherian1982
Dec 31, 2008 08:17 AM
em2ssm02
Aug 9, 2008 11:41 AM
Gumbey75
Feb 26, 2005 10:32 PM
Origin
25
Feb 25, 2004 05:59 PM
nousername
13
Jun 17, 2003 10:28 PM
