whats my compression
Old Jun 19, 2009 | 09:07 AM
bakomack's Avatar
Default whats my compression
im confused on my compression. ive been told im gonna be 10:1 to 12:1 i dont understand how to calculate it out.
i have a b16a stock crank and stock rods. CTR pistons. the head hasnt been milled I dont think.
what compression can you safely run on 91 pump gas?
will aftermarket cams bump up the compression? im running blox type b cams, brian crower ss flat face valves.
thanks
Old Jun 19, 2009 | 01:22 PM
bakomack's Avatar
Default Re: whats my compression
anayone have any input?
Old Jun 20, 2009 | 09:17 PM
numberone's Avatar
Go to the faq's . The cr calculator is in there.
Old Jun 21, 2009 | 08:15 AM
h224thgensedan's Avatar
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/diy-compression-ratio-calculation-2476094/
Old Jun 22, 2009 | 04:00 PM
DAMotorsports's Avatar
http://www.c-speedracing.com/howto/c...c/compcalc.php
use that site and if you are tuning the car they can make it run on 91.
Old Jun 23, 2009 | 09:07 AM
bakomack's Avatar
ok I need help im using this calculator
http://www.zealautowerks.com/bseries.html
b16a block, b16a crank, b16 head, PCT piston standard bore, b16a rods, oem 3 layer head gasket, the guy who ported my head told me to mill the head 20 thousandths ( havnt done it yet, is 20 thousandths labled .020"? )
max rotating rpm 8500
elevation 300 feet
if I calculate those and leave the milled section at 0 heres the results and the screen turns yellow.
static comp ratio. 11.91:1
effective comp ratio. 11.85:1
if I put .020 for milled the screen turns red
static comp ratio. 12.76:1
effective comp ratio. 12.70:1
Old Jun 23, 2009 | 12:23 PM
it looks like it is yellow because the piston to deck is a -.07 and you might hit the head with the piston
Old Jun 23, 2009 | 12:48 PM
bakomack's Avatar
oh ****. well what does the red mean lol. I didnt have anything taken off the head i just had it surfaced and im using a oem 3 ply gasket
Old Jun 23, 2009 | 12:51 PM
with the one i posted it looks ok. u will have to clay the pisno to head/ valves to check and see if you have the room. i dont see y it should be a problem but have it checked and be save.
Old Jun 23, 2009 | 12:54 PM
DC_Legacy's Avatar
You should check with the shop that you had the head surfaced at to verify how much was taken off after it was surfaced.
I had my head rebuilt and surfaced and the shop I went to took roughly .005"-.010" off mine as was mentioned.
Old Jun 23, 2009 | 01:00 PM
01-0720's Avatar
the ctr pistons are your problem, the dome is to big on the piston, there to much trouble, get some p30 pistons, mill your head 20 thou, and run a 2 layer head gasket, youl have nice compression, when combined with the flat face valves you already have, and youl have much much more piston to valve clearance, and will be totally fine with 91 octane
you dont need huge compression to make good power
bakomack's Avatar
I will check with them on that im picking it up after work
Old Jun 23, 2009 | 01:01 PM
I could not have said it better.
Old Jun 23, 2009 | 01:02 PM
bakomack's Avatar
I dont have the time or finances to pull the pistons out and buy new. if I have to do that i might as well scrap the build and run ericks racing pistons with an ls crank and ls rods
Old Jun 23, 2009 | 01:05 PM
DC_Legacy's Avatar
Might i mention, Cometic makes different thicknesses of head gaskets from .030"and up which might offer an alternative to help lower the C/R and make room for additional deck clearance if needed.
Old Jun 23, 2009 | 01:06 PM
bakomack's Avatar
noted lol thanks i might look into getting one of those
Old Jun 23, 2009 | 10:06 PM
medorihb's Avatar
i did my comp check using the zeal calc. and mine is 11.67:1 on a D. using pg6 pistons....i melted the pm7's i was running when the vtec solenoid froze open about 2 years ago. switched back to the y7 head and put the pg's in and it runs pretty good.
bakomack
Jul 20, 2017 01:21 PM
seldon
Sep 4, 2009 06:29 PM
McFly
Dec 21, 2002 10:08 PM
Taloola
Aug 11, 2002 07:49 AM
