Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
installing new suspension
Old Jun 18, 2009 | 11:05 PM
patrickstar's Avatar
Default installing new suspension
hey guys i don't own a 06-09 civic but my friend does and im gonna help him install his new lowering springs. i've never seen your guys' suspension set up before.
is it the same as all the other older model civics? bolted up through the shock tower. connected to the front forks and rear lcas? and lcas to the hub?
anything else we should know before continuing? thanks
Old Jun 19, 2009 | 01:38 AM
pd0019's Avatar
Default Re: installing new suspension
fronts are pretty straight forward...make sure you put the right spring on because they are side specific.
rears are pretty easy as well. it is a lot easier if you disconnect the swaybar, but it isnt necessary.
Old Jun 19, 2009 | 05:08 AM
jloehlein's Avatar
It's pretty straightforward. The only odd part for me was the access to the top mounts on the front of the car. Try not to drop any nuts. If you do, it is helpful to have a long magnet handy.
Old Jun 19, 2009 | 12:09 PM
alright thanks for the advice guys!
KraZyCHOWMEIN
Mar 25, 2016 05:14 AM
F22PwrdS2k
Honda S2000
15
May 8, 2009 12:06 PM
MulticolrdLude
May 28, 2007 11:04 AM
knowles_101
May 13, 2004 10:49 PM
SuperRice
Sep 7, 2002 09:03 PM
