which of these do i get?
Old Jun 18, 2009 | 10:18 PM
94civicdeleon's Avatar
Default which of these do i get?
I have a b16a with already a aem fuel rail, skunk2 intake manifold, i/Dc Headers/E, stage 3 act clutch and I want to know (What are the best cams to get without spending so much money cuz im a little broke as hell.)
Like my credit is so bad they won't even take my cash.
So that is my question which cams are the best to get and i use this as my daily driver so idk if that matters.
Old Jun 18, 2009 | 10:20 PM
DCRB's Avatar
Default Re: which of these do i get?
no experience w cams YET but i'd say skunk 2 stage one cams? works w stock valve train. supposed to give good results. that's what i'm getting for my hatch...
Old Jun 18, 2009 | 10:44 PM
Redline130's Avatar
If you are on a budget, look at ITR or CTR cams. If you are on an even tighter budget (which is sounds like), you might want to look at GS-R cams.
Browse through the classified forums, you might be able to find a good deal on a set of used cams.
Old Jun 18, 2009 | 11:41 PM
helpmycivic's Avatar
i agree if you are on a real tight budget look into some gsr cams. they are a little bigger then the b16 cams, if you have a little extra money go with some ITR cams. do some research there are so many different aftermarket cams out there it all depends on the performance your looking for and how deep your wallet goes. good luck
Old Jun 19, 2009 | 11:03 AM
dephtone's Avatar
I picked up GSR cams for my boosted b16, which give great mid range, however, I have seen that on a NA application, you won't get much MAYBE 1-2 hp from what I'v seen.
Found mine locally for 50 bucks in pretty good shape.
DCyPHeR
Sep 11, 2004 05:46 PM
buggsy458
Sep 26, 2003 09:36 AM
jaydmcrx
May 7, 2003 11:12 PM
wrXtian
Mar 9, 2003 06:07 PM
