Possible to mod LCA to Fit 97 accord?
Old Jun 18, 2009 | 08:00 PM
carcoolguy9's Avatar
Default Possible to mod LCA to Fit 97 accord?
I have concluded through 3 different forums and hours of searching that there is no aftermarket LCA for the 97 Honda Accord EX. So that being said i was wondering if anyone thinks it could be possible that a Civic LCA or an Integra LCA (or any other honda LCA) might fit with some slight modification?
Think its possible or am i a fool for looking into it?
Old Jun 18, 2009 | 08:20 PM
accordhybrid's Avatar
Default Re: Possible to mod LCA to Fit 97 accord?
Hit up Iakona on hondasociety.com he had some custom ones made.
Old Jun 18, 2009 | 08:34 PM
GhostAccord's Avatar
What do you need them for? Looks or do you want them to perform some sort of adjustable suspension function?
I looked around for aftermarket rear suspention upgrades and found nothing. I'm not slamming my car to the ground but I am planning on stiffening everything up back there with some DIY poly urethane bushings.
Old Jun 18, 2009 | 11:23 PM
BBallz24's Avatar
I think he said $200 for some custom billet ones. Mainly for show
Old Jun 19, 2009 | 07:01 AM
I'll talk to Iakona and see about that. The main reason i want to try and get an aftermarket one would be because i think one of the stock ones that i have is bent slightly. The car was rear ended a while back and the mechanics told me one of the LCA's bent, but not badly enough to change it then. Now that i have some money again and time to work on it i figured i might try out a new one. The show aspect is just a plus really.
Old Jun 19, 2009 | 07:11 AM
It's $80 for two OEM replacements vs $200+ for custom. If the only reason your doing this is to replace a suspected bent LCA. Why not buy one OEM and replace the bent arm. Then use the $160 that you save for something more useful?
Old Jun 19, 2009 | 07:42 AM
JDM_CD7's Avatar
Wouldn't waste my money or time looking for those rear LCAs.
If you need any adjustments in the rear you should invest in some Wicked Tunning Rear Camber kits.
There around $150-160 and worth the money.
Old Jun 19, 2009 | 08:02 AM
TheMuffinMan's Avatar
He knows where you live!
DIY Rear Washer Trick > Camber Kit
Old Jun 19, 2009 | 12:23 PM
732xghost's Avatar
megan racing make rear lower control arms and rear toe bars. they look kinda weird and only come in blue.
carcoolguy9
Jun 14, 2009 07:43 AM
W0P
Mar 19, 2004 07:57 AM
im_the_teacher
Audio / Security / Video
Oct 3, 2003 12:20 PM
Riceburner247
Acura TL, RL & ZDX
Feb 17, 2003 12:57 PM
