Axle don't fit? (SiR First Gen in EF Hatch)
Hi,
I've been working on my EF last night, swappin a B16A first gen from a teg X-SI (DA6).
I've used these axles: B16A midshaft with teg 90-93 axle, both side.
Here's the problem.
Everything fits all right BUT, when I tight the bolt (axle bolt) from both side, it doesn't screw all the way (I can, but if I do it, the wheel won't turn, like if the bearing was soooo tight)
If I tight the bolt half the way, it's all good, but the wheel shake from top to bottom...
I've removed the dust shield, maybe there's something else I need to remove?
All the spline and stuff is ok...
Anyone had the same problem?
Thank you
Here's the problem.
Thank you
sEa lOS gRill
Jul 9, 2009 08:53 PM
CRX7
Nov 20, 2002 12:55 PM
ZeRoFouR-EF9
Apr 4, 2002 06:19 PM
