H22 H23 Lower timing gears
Old Jun 18, 2009 | 05:23 PM
Acidcrakker's Avatar
Default H22 H23 Lower timing gears
I know that they are both different. But I hear that you can use either one on either motor. Anyone have any insight into this.
Old Jun 18, 2009 | 05:28 PM
kornerk12's Avatar
Default Re: H22 H23 Lower timing gears
bump
Old Jun 19, 2009 | 09:03 AM
PirateMcFred's Avatar
They are NOT interchangeable. They are if you want to r=uin your engine.
belts are different lengths and the teeth are different
Old Jun 19, 2009 | 09:33 AM
ludetech's Avatar
yeah i work at honda trust us dont try
Old Jun 19, 2009 | 10:20 AM
95greenlude's Avatar
both gears will fit over the crank if thats your question....whether to use them is another
Old Jun 21, 2009 | 04:04 PM
Nah, I remember seeing in someones build before that they used the H23 timing gear on and H22. It must of been a hybrid block build than.
Thanks
Old Jun 21, 2009 | 04:17 PM
Anton LaVey's Avatar
you use the h22 timing gear when building a h23vtec frank motor
Old Jun 21, 2009 | 09:17 PM
timing gear matches the head you're using
SilverEk3dr
Nov 1, 2022 08:21 PM
silentvoice19
Apr 26, 2007 08:07 AM
Jmoto911
Feb 28, 2007 12:21 PM
hybridpatient95
Jul 18, 2005 01:12 PM
k24a4kid
Jun 6, 2005 01:50 PM
