removed my s2000 badges and ran into a problem
i removed them and the driver side went perfect came out clean and everything but the passenger side one had like a glue or adhesive underneath
what should i do? goo gone for cars did not work lmk
ya i just need to get it off it kills me inside (s2000 owner insider) has anyone worked with 3m general adhesive remover a friend told me its safe to use on car finishes and it strong stuff.....don't know where to find it tho... i have checked auto zone, advance auto, walmart, target and ace hardware
Also, this very topic cam up just a few weeks ago, so please search next time.
Many auto parts stores do not carry allot of the 3m stuff.
Please dont use a magic eraser. You will need to buff and wax after and it's just not needed. If you would just take my advise you will see the adhesive will come off very easily with heat, soap and water.
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
This stuff works good, spray it, let it soak for awhile, repeat if necessary.
http://www.superiorcarcare.net/stonxenincle.html
Use a product called bug and tar remover. It works great for that kind of stuff and also will not harm your paint. Just dab in on the glue spot and let it sit for a couple mins then rub off with towel and a little elbow grease.
kk ill try a couple things and keep everyone posted but i want to make it clear its not the oem adhesive its like a super glue or a hot glue i dont know what this guy did
BRAKE CLEAN. DO it quick. Then you gotta clean the area real good and polish it up. Works great!!! Doesn't eat the paint if you do it with some quickness and then clean it up right away. I've done my car and seen other cars done too.
krshultz
51
Oct 17, 2005 08:37 AM
