what should i use to tune my 96 accord turbo
yes what would be the best way to tune as in what should i get to tune my accord if anything im gonna be runnin 6 psi on the stock motor and have no idea whats best to use to tune it any info lemme know asap thanks.... can i just use an afc controler or a different ecu and if so which 1.. should i get hondata if i even can...
Is it already turbo'd ?
You don't want an AFC.......
Downconvert to OBDI and run a chipped ecu. You need to do way more research first.
not turbo yet got everything besides a downpipe and tryin to figure out the tuning sitcuation so what is there like a harness to conver obd2 to obd1 or....
Lol yes you need to do more research. Downconverting the car to OBDI will give you tuning capabilities. I believe there is an "Engine Management" forum section.
