well b mounts work for d?
i found these mounts that id like to get cuz well mine and stock and all ripped to hell. im going to be doing a b swap in the next year, so i wont to know if these mounts will work for both engines.
link to mounts: http://cgi.ebay.com/ebaymotors/HONDA...1%7C240%3A1318
i have a b18b in my 93 civ and i have a d series mount on the trans side with a poly insert lines right up and my rear mount is also d series pretty sure just the engine side doesnt line up man if your planning a b series swap pick up the mounts
Do not attempt to put B-series mounts on your D-series engine. Leave the stock mounts alone unless the actual metal is torn (it's not) and get new mounts for your new motor when you get it. Think about it: if the mounts were the same, why would they specify B-series and D-series?
Exactly.
Exactly.
Exactly.
Exactly.
92-95 civic, 93-97 del sol, integra 94-01 mounts are the same. Only different between B and D are is the "T" bracket in the rear.
Hasport B/D mount
2 bolt http://hasport.com/shop/product_info.php?products_id=35
3 bolt http://hasport.com/shop/product_info...products_id=94
Not sure with year came with 2/3 bolt on engine side mount. Check before you order.
Hasport B/D mount
9 and 10 in both diagrams for drivers side mount is dif. i hav a dx 94 and put a gsr motor in and the stock D mount for the driver side didnt work so i had to use the gsr mount that wasFREEEEE
Exactly.
Exactly.
Hasport B/D mount
Hasport B/D mount
only 94-95 ex, si, vx came with the integra style 3 bolt driver side mount
Exactly.
Exactly.
Exactly.
Exactly.
