Broken Bolt in Motor mount! Help!
My b18c had a broken bolt on the driver side mount. Before swapping it in i used a easy out and drill the broken one out and used a new custom bolt...I tried another honda but it wasn't long enough...I retread it as well...... Now it broke again! WTF! I need suggestions! Heli coil? or what should i do? is there a way i can do without pulling the motor out again? Suggestions? anything..Thanks
Have you tried jacking the driver side of the engine up with a floor jack. I had similar problems before and was able to hoist mine up just high enough where I could drill it out.
deerman2701
Oct 19, 2012 01:17 PM
Herminator
Welding / Fabrication
Oct 22, 2005 04:00 PM
